Switch Satel outputs with HC2?
I've setup integration between my Satel and HC2 ... everything seems to work ok but, i'm unable to switch Satel "BI switch" outputs from my HC2.
So: is it possible to switch Satel outputs from HC2? and how?
5 answers to this question
cant switch them either..
i have setup a biswitch ( sunrise/sunset ) it is always on ..... i try and switch that to off from home center but keeps on always....
also i have external sirens show at the output.... i try to switch them on..... nothing happens
Hi Guys,
All is possible, after the integration of the Satel Integra alarm system you have to fill in an existing user code from the alarm system. (see image).
To control any output of the correct type, you have to put them at least in one partition, otherwise they won't work!
Please remember that you can only control 24. MONO switch, 25. BI switch, 105. Roller shutter up, 106. Roller shutter down and 64~79 Remote switch outputs!
Br Taco
    I got it working with the help of Osec/Taco
    /emoticons/default_icon_cool.gif" alt="8-)" /> Be sure that you're not using the service user code (i was ...) and make sure the user you use has the "23: Access to BI && MONO outputs" privilege.
    Thank you Thank you Thank you
    We are getting there !!!
    step by step......
    so now we know which outputs we can control from the HC2
    Hi, do you know how to authorize Satel Integra in order to grant access from HC2 via ETHN-1?
    at the moment I'm able to log in via guardX and make changes trough the keypad (trough Admin menu) but not able to log in via DloadX.
    Thanks,
    Gianluca.
