Shad 4
I saw many problem with minimote, so I remember a howto on french forum.
At this moment I set like 12 functions with only 8 buttons
I make a script to have a virtual menu and use short/long push to navigate inside.
So for start he to use normally the minimote, just replace id:
So now, here interesting things:
1) ambience
So I prepare a scene with 4 ambience, so make global variable with predefined value:
- Normal
- Cinema
- Music
- Romantic
Also for my script you need global variable nightime.
So here a scene with all ambience
Then, in the scene of minimote put function for manage that:
and the code for button:
That's all, just do short/long push to navigate to next or previous ambiance.
2) ALARM
It is possible to arm you alarm with minimote and don't arm the one where is breached and sent push with you own message by sensor.
So here the function to put on the top on your code just replace Id of sensor/phone and message:
And In minimote:
So short push you arm and long push you desactivate alarm.
3) Blind
The next can be change for many, but with roller shutter you have a good example.
So with 2 buttons you can have 4 position to your blind.
button 1 = 50% or 75%
button 2 = close or open
and for minimote
So you see with 6 button you can set 4 ambience, easy system to arm/desarmed alarm and 4 position for roller shutter.
