Help programming
Hi:
I've been searching for a while for ways to integrate HC2 to different alarm systems. Right now I am working with a DSC PC1616 panel with a Envisalink 3 interface
They provide a TPI (third party interface) programming guide (attached), but I can't get it to work.
My programming skills are pretty rudimentary and when they start talking about binary, hex and ASCII commands I get really confused.
I managed to open a TCP socket from terminal app on a MAC, but can't manage to send commands to the alarm panel. I always receive a "syntax error message" (50202029).
Could someone help me with a few sample strings to, for example, arm or disarm the alarm, in order to understand the protocol and start working on a virtual device to fully integrate the alarm to HC2?
Example: Partition arm control - with code
Command code: 033 (ASCII 30 33 33)
Partition: 1 (ASCII 31)
User Code: 1234 (ASCII 31 32 33 34)
Checksum (according to my inexperienced calculation): 0x1F1 (ASCII 66 31)
I tried the following string with no luck (always received "syntax error" message):
303333313132333466310D0A
30:33:33:31:31:32:33:34:66:31:0D:0A
If someone could point me in the right direction would be great in order to start working on the integration of DSC panels.
Thanks!!
Guest Lode
Does your system have anything like API ?
    Sorry, forgot to add the attachment, now is included in the original post.
    Its a TPI (third party interface) programming guide. The closest to an API I was able to find
    [ Added: 2014-04-11, 00:25 ]
    Found the answer
    the code shouldn't be converted to ASCII (just to make de checksum)
    The correct string was:
    0331123491
    Mac terminal adds the line feed (LF) 0A automatically, so it is necessary to add the CR (0D) to the end of the string. on terminal is control + V
    Now I want to send the string directly from HC2, but I can't figure how to open the TCP socket from HC2 using Lua. Anyone?
