hi all,
I am new into this and not very expert on electrics. I just bought a HCL with 2 Fibaro sensors and 2 2*1,5 relay switches.
I am having problems installing the switches. The first one I try to install is without any switcher as I want to fully control it with the HCL.
The one I installed has been detected by the HCL and I can hear "click" when trying to switch it on/off. However nothing happens with the lights.
To make it simple assuming only switch, what would be the connections S1, O1 and I? I have try to find some tutorial but from the ones I found I cannot solve my problem.
thanks!
I think you didn't connect a live wire to the "I" terminal.
I= input
O1 =output 1
When you don't want to use a switch you don'nt need S1 terminal
Good luck!
    Thanks that worked!!
