Dalle1985 16
Hi guys,
I don't like the way the heating panel works. It lacks the kevel of flexibility I want. Therefore, I've built my own heating scheduler. It allows you to set up individual temperature schemes for each room individually, for each day of the week with up to 16 changes pr room. It also has a feature for turning down the temperature in a single room or in the entire house if you open windows or if you engage vacation mode ( which will automatically return to the normal schedule at a predefined time before you return home). It will then automatically change temperature as the day progresses.
If anyone need to trigger a boiler, I'd be happy to help getting this working, but i would require a bit of information to get it working.
It has been setup using danfoss thermostats, but it is pretty straight forward to adapt it to other components.
The script is based on an external webserver with php5 and MySQL so these are needed to make the script work. Furthermore, there is a scene and a virtual device, so no HCL use (or at least you need some workarounds to use the script as it is triggered by the VD)
Right now, i have it set up to run on my wall mounted tablets only (1024x600), but if enough is interested, I will create a nice package for easy install and a how-to for installation and use. So is anyone interested in this?
5 answers to this question
