In my house I have City Heating including Hot Water
This means there is always hot water and heating available.
Using the Fibaro universal sensor and external temperature sensor I can monitor the hot water.
This gives extra possibilities in the Scenes.
When shower hot water temperature is above 30 degrees turn on the ventilation.
When heating temperature >35 heating is on.
Nice work!
Regarding
Ventilation scene can be also done with a humidity sensor in the bathroom. Nevertheless I like your solution because no batteries are involved.
    I have also the Everspring Humidity sensor in use.
    Detection via humidity is a bit slow and wil not always work..
    I few seconds the temperature via Uni sensor will be above 30
    Also setting some other triggers...when Hot water of kitchen or the bathroom >30 there is someone in house.
