Can the RGBW module somehow control a strip of RGB and seperetly a set of White light.
It have to Work independently, because its in separat rooms.
Can someone give some feedback on this ?
I have seen something like this in the manual, but i can not find it in the UI ?
Some help ?
Best is to use Lua
see example.
I control 4 different white led stips.
fibaro:call(545, "setColor", "21", "31", "15", "12")
you can make virtue device for every room
this one will set the with on
fibaro:call(679, "setW", "255")
Red.
fibaro:call(305, "setR", "255")
    Thanks TANE..
    Is there a possibility to control the virtual devices by input 1-2-3-4 ?
    Best is to use Lua
    see example.
    Setting the RGBW module to the Input / Output mode and configuring all 4 channels as independent outputs does not work for you?
