Manual operation not working with FGR222 Roller Shutter
I have a Home Center Lite with a Fibaro roller shutter v2.
I connected the roller shutter to my blinds according to the schema in the manual.
I can operate the blinds with by the fibaro system but my switches (up/down) are not working at all.
My parameter settings for the switch control are on momentary switch.
Did I miss something to configure?
Did you connect the Live (brown) wire to the switch? It's a common mistake to connect the neutral (blue) wire to the switch.
Please check your connections again.
    Yes, connections on switch are:
    Brown (live)
    S1 --> FGR222 Q1
    S2 --> FGR222 Q2
    Blue (Neutral) is coupled directly from power source to blue on FGR222
    Brown, live, goes to your manual switch
    From your switch 2 wires go to the module. One to S1 and one to S2. These are for the manual control.
    Live (brown) also goes to L and neutral (blue) goes to N. This is the power supply for the module and your shutter.
    Next Q1 and Q2 go to your shutter motor (rotate left or right).
    If you have connected all of this and it still does not work your module might be broken. I can not think of anything else.
