Virtual device's icon disappearing every click
Hello!
Software Version: 3.591
Making virtual devicу for Dune HD player.
Add 128*128 icon for tha device. If I click on the device in the room page - the icon reverts to the 3D blue cube until I manually re-add the icon in programming mode.
Is it a bug?
6 answers to this question
Guest Kuuno
no, every button has an icon and default is blue box...
No it isn't.
You have to change the buttonicons also in the advanced tab. The main icon is changed to the icon when a button is activated. So you'll see the last buttonicon which is activated.
When you save the virtualdevice, the icon is changed to the main (default) icon.
You can also change an icon by lua, for example, when adding this code to your main loop:
This code will change your virtual device icon every 3 seconds. (last icon will be there for 6 seconds because the main loop has a 'build-in delay' of 3 seconds).
Btw, I didn't test the code but it should be working, it's just intended for explanation.
    Thanx.
    Can't find any logic of changing the icon on key pressed
    Sorry.
    Try This on every button
    local selfId = fibaro:getSelfId();
    local icon = fibaro:get(selfId, "deviceIcon");
    fibaro:call(selfId, "setProperty", "currentIcon", icon)
    Thanx, Kage!
    It works fine now.
    This is helpful, however is there a way to get the image the device has right NOW? Because if I change the icon within the code but don't want to let it change to the buttons icon nor the default icon.
