rajp 14
Need guidance on how I should have wired my 500W relay. I have my house's front lights switched on and off using a Wise Wireless relay switch. This has worked for approx 5 years without any issues. However, as I wanted to set everything up in HC.. I decided to replace the relay with a Fibaro 500W relay as the circuit is a 2 wire type.
I did the following.
Switch the power off from the fuseboard.
The Brown from Switch connected to the L on the relay.
The Blue into N.
I put a small cable that goes into N and O.
I connected the Brown to the lamp into SX port
Connected Blue into S1
Once all this was done, I switched the power back on for this circuit. As soon as I switched on the light, I heard the fuse trip. Stupidly, I tried to switch the circuit back on and heard a bang near the relay. I assume that was my expensive firework.
Have I got my wires in a tangle?? Any guidance would be greatly appreciated. I have refrained myself from trying something different and have got a electrician coming in on Friday to see what happened.
Thx Raj
4 answers to this question
