Triggering scene issue
We have created a scene for triggering the water pump connected to Fibaro Wallplug at exact time in the morning and evening and set the notifications that if motor is ON then send push notification to the mobile as "Water pump is ON".
The scene is as shown below
We noticed that when there is a power failure the motor is not turned ON and HC2 has sent a push notification as "Water pump is ON".
We failed to understand, if the motor is not triggered why HC2 has sent push notification.
Please help us to find out what is the issue and also like to know whether the scene we created as discussed above is correct or not.
5 answers to this question
because in scene you dont checking is pomp is ON you only sending command turn ON, better do that on few scenes and check is device got state what you wanted
    Hi Socha, thanks for your reply
    Can you help us on how to create a scene for checking the state of a pump.
    Do something like this
    1 scene
    2 scene
    3 scene
    Hi Socha,
    First thanks for your solution, the code is making some sense
    Is it possible to create the "1 Scene" and "2 Scene" as a single scene.
    [ Added: 2014-04-25, 17:03 ]
    in LUA yes in blocks no
