ivalentinov 0
Hi guys, fairly new to the forums, so excuse me if i ask stupid things
/emoticons/default_icon_smile.gif" alt=":-)" />Currently i am testing the system and loving it so far, but cannot get past this:
I have a motion detector (the fibaro motion detector) and i want to turn off a plug in the room after 30 minutes of no movement. I can easily do this with the scene block-builder, but at moments i can have more than 10 instances of the same scene sleeping. I am sure that with my simple test setup this is not a problem for the HC hardware but wonder what will happen if i have 20+ scenes each with timeouts.
As coding is no problem, i switched to lua and tried to optimize the scene and have only one instance of it, however it turns out that what i can do is either abort the newest instance or kill them all, when in fact what i want is to kill the older instance and keep the newly triggered.
If you have something to advise me that will be great and if this is not possible at the moment, maybe someone from Fibaro can tell us if and when this will be possible.
If this was already discussed - i apologize in advance.
11 answers to this question
