TANE 12
Few weeks ago reported a method using the Uni sensor to detect if there is need for ventilation in the bathroom.
I have added a extra sensor to the system to report the cold water temperature.
When there is cold water usage the temperature of the sensor will go below 20 degrees in few seconds
Using this sensor you will know there is water usage without need of a water meter sensor.
This sensor can trigger a alarm...when you are on vacation and there is water usage...or detect presence in the building...
Ps All the sensors are just 1 Uni sensor..with 2 door sensor and 4 temperature sensors connected
