As you know we can do logical expressions in the scene editor. Some of my "expressions" were ugly to look at so I tried to optimize a bit.
Let's say we want to implement this expression:
How could we do this HC2/HCL scene editor?
/files/thumbs/t_abc1_663.png" alt="t_abc1_663.png" />
In this first graphic (abc1.png) a wrong example is displayed. The expression will evaluate to:
This logic is not what we intended as C can cause the scene to run regardless of the 2 other variables. (This is because AND operators are processed before OR operators in general)
Second example implements the right expression in terms of the result:
/files/thumbs/t_abac_191.png" alt="t_abac_191.png" />
But in reality we have implemented this:
So how can we get the shorthand form in the scene editor? Well it turns out the yellow box containing the THEN clause can also act as an AND/OR clause:
/files/thumbs/t_abc2_508.png" alt="t_abc2_508.png" />
Notice the subtle difference between image 1 and 3. the AND clause on a separate line actually implements a () around each section before and after. So here we have implemented this:
On top of that it improves the readability of the expression. Unfortunately you have to delete everything after the THEN box before you can turn it into an AND/OR operator instead.
A curious "feature" in the scene block builder is this expression that you can build
Now I have no idea what that will do as it literally defies logic :-)
Anyway - Hope this post helps someone out there.
4 answers to this question
Thanks for making the tutorial.Someone has to explain all the syntax
Thanks , great finding
[ Added: 2014-05-02, 15:14 ]
I just tried this to fix all my lights / xbmc status scenarios , before that they were going crazy .
I can't believe that Fibaro team doesn't have these written somewhere , i begin to doubt they even know about it .
We are constantly working on Fibaro advanced tutorials. In following editions we would like to include such hidden options like you have described above. Thank you for sharing your knowledge at forum.
