Hello I'm pretty much new here but, I have some questions / ideas about the FGBS321 Universal Binary Sensor EU.
I know that you can configure it in several ways. But I find the options and settings from which you can choose very limited.
My configuration: I have several FGBS321 installed all as them sensors which leaves you with IND1 and IND2 ports. Some of those I use for scene activation, but others I want to use to display if a electrical machine is active and running with its fixed power consumption ( similar as the relay switch 3kW and the 2x1.5)
Maybe it is a possibility in the sensors main screen to add some more device type and if you could put a value to it..
Fibaro: HC2
8 Dimmers
3 Wallplug
1 Aeon4-1
1Motion Sensor
7 2x1.5 kW switch
4 Universal Binary Sensor
3 door/ window sensor
