donangelo 0
Hello
I use the Z-Wave Fibaro Relay Insert 2 * 1.5 KW switch to turn on and off the lights.
Now I have the problem, that Switch 1 turns on the lights, but if I want to turn it of I have to first switch it off on fibaro and then push one again ON, then it turns off. And then send OFF again, that I can switch it ON with OFF.
So SEND ON+OFF to turn it ON
then send ON + OFF to turn it OFF.
What is wrong with my configuration? If I don't send OFF after turning it on, I'm not able to turn it off on the wall switch.
The other problem is with the other light. There also like switch 1 - SEND ALWAYS ON + OFF, but OFF doesn't switch off the lights but only dimm it down.
The switches and lights are all connected with BeamIT Zetrion from Feller, whitch is already a kind of home automatism.
I think now that the Impuls that I send is to long. I had the same problem with the rollershuter, but configure it to 0.1s solved my problem.
Any Idea what could be wrong?
Thank you
Angelo
4 answers to this question
