pathduck 18
Hi i have created some smoke detector scenes for sending push notifications via pushover. The reason i want to do this is because pushover allows for bypassing the android sound profile allowing me to activate an alarm sound on the device even if it is in silent mode.
I have created a scene for this and the pushover functionality is working. My problem is that it is only functional during breach and not when the smoke sensor detects smoke.
If i take the sensor out from its frame activating the brach alarm it will send a pushover notification. But when the sensor is exposed for smoke it will not send a notification, the sensor goes off and the Fibaro push message comes through but not on pushover.
What am i doing wrong? Is there another setting i need to use in the scene window, like open or close?
when i am exposing the sensor to test smoke it has not been in its frame, does it have to be?
After some more investigation it seems that 3 of my smoke sensors (wich i have tested) are not sending any signals to the controller. nothing is stated in the event panel. Also the B button is not very stable. pressing it in for the self test works but there is no way i can make the tripple click for wakeup. Seems like there is a problem with the spring function in the button and that it is not returning properly. i have to manually jiggle the button to release it again. anybody else experiencing this?
