Hi guys,
Anyone can enlighten me? I tried implementing a Net.FHttp code into a scene but there's error with the Net. Does http/tcp codes all work in scene function? Or they only worked under the main loop and virtual devices? Because I'm currently getting data from a google api.
Thanks in advance and wish you guys a great day ahead.
Malvin
As far as I know this only works in virtual device loop and button. You can store the data in a label which you can read for use in a scene. Search the board for examples.
