I recently bought a Vision Door Lock for my Fibaro System. But I´m not sure, if this device is supported from Fibaro.
I thought, that it would be a good idea to include this device in my home automation and to activate the alarm right after closing the door (it´s more convenient than a remote control and it´s intuitive to use).
I expect a lot of work for changing the door lock because it doesn´t fit without drilling new holes. Does anyone know if this device is supported from my Fibaro HC or if it will be supported in the near future?
vision by locks are not yet working on the fibaro home center.
hopefully I'll be waiting there too.
regards Hennie
jojo1967, should wok in 3.901+
    Thanks a lot
    • 1 year later...
    does the vision zm 1702 door lock already work with HC2?
    • 4 weeks later...
    I just finish to installed the ZM1702. The HC2 recognoized it in the right way. But I can't close the door. I've allways get the green light icon . Any ideay? Thanks
    • 3 weeks later...
    Hello, I have a Vision ZM1702 and I've tried all day yesterday to connect it to my HC2. I have the latest update on the HC2. After several tries I didn't succeed to instal. On the HC2, in the learning process it shows nothing. I've also kept the HC2 close to the door lock but still nothing. Can you please advice on how to install it, or if there is a way to factory reset the ZM1702. Also I've tried to install a Schlage Z-Wave door lock but also didn't work.
