Guest Eduardo
I´m trying to make my minimote to control my TV. I´ve already managed to activate the scene to turn on and off the TV, but the comand to change the channel on the button 1 at the minimote doesn´t work. I just receive this message: line 19: attempt to call method "presButton" (a nil value).
This is the minimote config.
%% properties
114 sceneActivation
%% globals
local ButtonPressed = fibaro:getValue(114, "sceneActivation")
if ( tonumber(ButtonPressed) == 1) then
fibaro:pressButton("button_2_0")
fibaro:debug("MiniMote button 1 pressed - ch mais")
elseif ( tonumber(ButtonPressed) == 2) then
fibaro:call(17, "close")
fibaro:call(64, "turnOff")
fibaro:call(67, "turnOff")
fibaro:debug("MiniMote button 2 pressed - lab all off")
elseif ( tonumber(ButtonPressed) == 3) then
fibaro:call(87, "turnOn")
fibaro:debug("MiniMote button 3 pressed - alarme on")
elseif ( tonumber(ButtonPressed) == 4) then
fibaro:call(87, "turnOff")
fibaro:debug("MiniMote button 4 pressed - alarme off")
elseif ( tonumber(ButtonPressed) == 5) then
fibaro:call(85, "turnOff")
fibaro:debug("MiniMote button 5 pressed - sirene off")
elseif ( tonumber(ButtonPressed) == 6) then
fibaro:debug("MiniMote button 6 pressed")
elseif ( tonumber(ButtonPressed) == 7) then
fibaro:startScene(22)
fibaro:debug("MiniMote button 7 pressed")
elseif ( tonumber(ButtonPressed) == 8) then
fibaro:startScene(23)
fibaro:debug("MiniMote button 8 pressed")
else
fibaro:debug("No response")
