Does anyone know, if it is possible to use a fibaro dimmer sensor under a regular dimmer switch (cause I already have one for my lights in the living room, but I want to use them via Z-Wave too)...
You cannot use the Fibaro Dimmer with a traditional dimmer switch.
This would create a conflict as you would have a dimmer trying to control a dimmer.
Instead, the Fibaro dimmers can be used with standard 'toggle' or 'momentary' switches. More information is in this guide -
    Thanks - that's very helpful!
