Yes, i know it is not zWave.
WiFi, indivifual socket control and power monitoring and in the €60 price range.
Why not just use the greenwave 6 port?
What's the advantage of this device?
    Well, apart from no local retailers, I am under the impression that the greenwave does not have the neccessary approvals.
    ok, I like the device as you sometimes only need 3 sockets and it is nice that you can attach it to the wall directly. But I think it will be difficult to have it included in the HC2. You could probably do it with a virtual device but it won't look / work very nice. For instance the energy measurements could be shown on a virtual device but will not be shown in your energy panel.
    It is quite easy to include it... The energy consumption can be shown in a label and even in the log line of the virtual device. The on off buttons can be made using a simple http request to the unit.
    The only issue I see is that it is wifi. The current wifi protocol (802.11**) really isn't suited for device networking. It is designed for relatively few, relatively large packets. So connecting a lot of "thing"-devices which send and receives a bunch of tiny packets can easily overload a wifi network creating huge latency or even crash the router at random. That is why you don't see a lot of wifi gear out there.
    Btw.: if you have a webserver and a bit of programming skills and understanding of http requests, you should be able to "cheat" your meassurements into the energy panel.
    Can you explain lithe more about that Dalle1985?
    Which is why i wrote "proper" support. I can control it from HC2, but it is still a "second class citizen" in the HC2.
    If you pull out the json from the appropriate device json in the api and then modify the json to include the showEnergy, valueMeter, valueSensor, you can http post it back into the virtual device json, and if I am correct, HC2 should accept it as an energymeter. I haven't tested it, but I don't imagine that hc2 is clever enough to distinguish... So you just need a way to update the valuesensor property of the json.
    [ Added: 2014-05-12, 19:15 ]
    It's back to the integration theme. HC2 is great for the administrative task of keeping track of everything but the user interface is rubish. I have a way of including virtual devices into my custom interface so for me it would be properly integrated... But you've bought a Z-wave controller.
    I'm sorry, but if you want something that can control EVERYTHING you need to create something yourself. There are no readily available products out there which will do all you ask of it. If the manufacturer makes it, they'll have to support it aswell. Just imagine the size of the task if fibaro had to support all sorts of wifi, zigbee, rfxcom devices along with xbmc, televisions, computers etc. out there... They have a hard enough time to include z-wave products.
    I think it is already a big thing that they give you http support to link in to other devices. This really has nothing to do with controlling zwave devices.
    The only thing that comes close is products like homeseer or domoticz... But even that isn't plug'n'play.
    Nope. I am not asking for Plug And Play, i do not mind coding.
    But a good developer guide for the API that Fibaro claims wiull be in 4.x would be nice.
    I am, however, not getting my hopes up for that to materialise even when 4.x is actually released.
    But yes, I am fully aware now that I picked the wrong controller.
    Sorry won't work. You can modify properties but not add them to virtual devices.
    I'm waiting for the EU version of this one
    Too bad! Could have been a nice trick though!
