Commands not implemented in scene
Hi guys,
Getting my hands dirty on GPS tracking lately. I added some key commands to track if my GPS are accurately correct. Added some commands like push notifications, debug statements and email notifications. Realized that most of the time, not all commands that are implemented are fully implemented.
For example, a scene where I reached 500m within my home, it will push notification to me stating that I'm near home, debug to show the distance from home, and email the distance information to my account.
In my case, most of the time the debug statement will work. Only push and email differs in its execution. I suspect it's because I'm using fibaro:calculateDistance for both push and email, if HC2 is unable to get my location and calculate it, it will do nothing, thus the push or email does not work.
Is there anything I can confirm this? Alternately I can store it first before sending it via push and email.
Malvin
5 answers to this question
As I understand correctly, you have created debug to notify you that you are in the close range of your house. What you are concerned about is if the "fibaro:calculateDistance" command works correctly or not. So right now, you would like to confirm if the value has been calculated or not, because you do not get push/email which base on it. Could you please confirm?
    Currently, the debug works fine with the fibaro calculate distance and fibaro get location of device.
    I'm currently using the same variables - fibaro calculate distance, fibaro get location vs home.
    However, sometimes the push notification does not come through that immediate, took some time to push or sometimes it does not push at all. but for the debug, it works fine.
    The push notification is passed on via Apple servers, therefore it can be delayed for a few minutes.
    All push notifications to iphone has to be pass on via Apple servers, am I right to say that?
    What about android?
    Yes, this is right. Android push notifications use another serwers, most probably Google's.
