I have just installed 2 fibaro multi sensors, and i got af very low LUX reading on both.
fully daylight 50 lux. is it possible to adjust this
Guest pablotibis
you continuously updates the brightness level?, in the morning when I open the window spend hours before the changes, you change some parameter?
tucmul, default value change which will trigger LUX report is 200 (parameter 40)
You can alter this parameter and put lower value (for example 50 or 100).
If this won't be enough you can always alter parameter 42 and turn on reports based on time interval - by default this function is off. If you want to try it do not use low time intervals (below 5min) because this will drain battery really fast. For battery life it is better to not use time interval based reports.
M. Roszak
