[Lua] Net.FHttp time-out command?
Is there a function in Lua to time out a net.FHttp command?
7 answers to this question
you should use Net.FTcpSocket or my lua framework (
    Just one question, is this installed in your stand-alone software (add-on) or can it work in the HC2 only?
    I don't use Windows and I don't want to make another (dedicated) server....
    It's a pure lua library for HC2
    How can I make a timeout without adding several pages of code?
    Is there any way without installing this toolkit?
    Guest merylion
    In old documentation on docs.fibaro.com which actually dissapeared
    You could see parameter to set request timeout in seconds
    Unfortunately I do not remember this very well
    Thanks for the hint. Hopefully someone can remember.
    Guest merylion
    I found something like that :
    local tcpSocket = Net.FTcpSocket(ip, port);
    if (not tcpSocket) then
    return nil;
    tcpSocket:setReadTimeout(250);
    I believe it sets timeout for receiving
    I only do not know responses when timeout is reached.
    Try to send tcpSocket:write(data) and watch response and error codes
    Regards
    Marcin
