Hello
A customer is asking about the internal components of Fibaro Roller Shutter 2 actuator.
He is worried that internally the actuator is using some over-voltage protection such as TVS-diode or most likely a capacitor. That could cause small voltage to leak through the circuit, resetting the end position settings in Somfy motors (he mentioned Oximo specifically).
Does anyone have experience with these motors controlled by Fibaro FGRM222?
  • 2 years later...
    Hello!
    It seems like Somfy Oximo io motors are equipped with Z-Wave radio (to use in Somfy TaHoma system).
    Does anyone have any experience with these motors? Are they compatible with Fibaro HC2/HCL 4.x?
    Disregard that, IO-Homecontrol is a different radio protocol. :/ (Z-Wave is apparently supported in addition to IO-Homecontrol on some Somfy TaHoma controllers.)
