Hi to all.
I need an motorized ball valve, it can be 230vAC or 24vDC and controlled with an Relay Switch.
I saw the
They had a ZWave version, that I don't know if it works with Fibaro HC2
Anybody knows any European Company that has something similar to this?
Atached WaterCop Manual
Thank you
5 answers to this question
Guest Kuuno
for better results use any 230v valve (NC) and a fibaro relay!
    The problem is that I can't use a NC or NO, because in the Winter I will use in NO and in the Summer it will depends, it can be NC most of the time and sometimes NO. That's why I need a motorized valve, so I can open and close when I want, and do not waste energy like the Water Garden Valves...
    Can't you use a fibaro FGS221 (2x 1,5KW output)?
    1 output to open and the other one to close a valve?
    Yes. I can use that, but I want to know if someone of you know a valve to do that in conjuction with the 2x1.5...
    ahh, okay. I never used it myself but maybe you can use a standard central heating valve?
