My plug with version 2.2. (22.22) refuses to show energy in energy panel. (pool heater)
When i edit the device it shows actual energy consumption only.
Older version 2.1 (21.21) show up correctly.
I have restart HC2 after inclusion of the 2.2 version. What can be wrong?
jompa68, press button reconfigure on him
    Did not help Andrew..
    Also tried to reconfigure all device in Configuration panel and then all my devices that was in energy panel are gone again.
    /emoticons/default_icon_eek.gif" alt=":shock:" /> Same as earlier and that time i was not able to fix it until i have started all over with a fresh installation (no restore from backup) and i don't want to do that again
    check do all wallplugs are configured and all got option show energy measurence
    They looks ok, but don't have option show energy in panel....
    jompa68, can you post screenshoot of adv settings?
    How much do you want to see?
    and why do i not got those values??
    both are visible when device is configured
    how can i force the reconfiguration?
    in advence settings there is a button "reconfigure device" press it and look on logs on top when you will see device from your plug on green then all process will be done
    tried that many time but without success....
    you are sure that device is in range?
    Yes, 6-7meters from HC2. But what about rest of the devices that have disappeared from EnergyPanel? Must be some bigger error in config or something that are miss-configured after the reconfiguration of all devices. All can not just disappear
    check do you got in zwave setting auto config for battery devices on yes and restart hc2 then try reconfigure
    Why have all devices disappeared from EnergyPanel? For example in API and on my Aeon Labs Energy Meter i can see that values are there, see picture. But it refuses to show in Energy Panel, have reconfigured device also.
    I have sent to support but no answers. Andrew can't you connect to my box and see?
