Stock market virtual device
Hi all,
here is a virtual device which reads values of a list of stocks using Google Finance APIs.
1. create a virtual device with IP and port as in the attachment
2. create a Label for every stock you want to read, and as ID use the stock symbol (see attachment)
3. Use the script as Main Loop:
In the script I managed to convert the "." to "," for decimals in italian, since I need it for a proper text to speech function (not in this code). Feel free to edit and keep it with the original dot.
Good luck with your investments!
4 answers to this question
Thank you, works great!
[ Added: 2014-08-28, 21:08 ]
Does not seem to work in 3.906 Alpha
Crashes alpha I think... According to fibaro devs > 20mins sleep will lock alpha? I have problems does anyone else fix lock problem by disabling this virtual device?
Any soloution on how to fix this? Still broken in latest beta.
    Hi, sorry i'm not yet on latest version.
    Have you tried to decrease the sleep to 15min?
