Just wanted to know if any 220V to 12-24V transformer is advised to be used with FGSS device ?
I have seen one like attached (350mA) and apparently it's enough "powerful".
They mention on the product's description that's it useful to power lights/LED but I guess it shouldn't be any different from powering FGSS module.
Thank you!
Be carefull with that. it is a led driver for a reason
it supplies the asked current with the necesary voltage and does not deliver a constant voltage. I do not think that it will work and may even distroy the device or the other way around.
    OK - Feeling lucky I asked
    Any advise ?
    No, have been looking for a small voltage power supply to build in aswell.
    Some LED "drivers" may work, but it is important that they have a constant voltage output, such as used for LED strips.
    If you find something, please do share
    [ Added: 2014-05-28, 16:20 ]
    Something like this could do:
    Just not sure how safe they are (A)
    As "LED" is also mentioned for these items, what says current is constant compared to the one in the picture I posted ?
    yours only has an output current with a max current. The voltage will change depending on the current.
    While the other ones show a 12v DC output voltage, with a max current. Therefor the output voltage will always be 12V and the current is depending on the "asked" power by the device.
    Something like this maybe?
    Thank you virgojavier.
    I'd put the adapter in a ceiling junction box so it better have a case to not be in contact to other cables. And my idea, if possible, is to not pay same price as the Fibaro module itself to power it
    I have ordered a bunch of these:
    I can let you know how and if they work well.
    Please do.
    30 May 2014 00:58 ? They even mention people buying their products
    haha, I think that is me indeed
    • 3 weeks later...
    btw should these module be armed manually ?
    I have two of them turned on and they don't react to smoke at all...
    /emoticons/default_icon_eek.gif" alt=":shock:" />
    No, they should be fine.
    They react to smoke after 5 seconds and 3 tries of having detected smoke. So maybe try longer.
    I couldn't find this topic anymore, but I received the power supplies yesterday. We will give them a try soon. They are very very tiny! Just wondering how safe they are... I mean you don't want them to catch fire
    /emoticons/default_tongue.png" alt=":P" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />
    Hello Stevenvd, any news regarding the power supplies ?
    I finally had my smoke sensor react to smoke
    /emoticons/default_icon_smile.gif" alt=":-)" /> There's no so sensitive, and now they freaking smell smoke like they burnt
