Hi guys
Does anybody know of a work about of getting a value from json?
For example, I will like to get if a device is switch on/off, i used html to get the json format information of the device, but without decoding, I cannot get the value from the full json format.
Anyone has a work about for this?
Thanks!
[ Added: 2014-06-26, 05:47 ]
Anyone has a way?
Been almost a month and no replies.
This?
local Table       = json.decode(tostring(fibaro:getGlobal(GVar)))
then get the values you are looking for using standard lua syntax
if there are keys in the json/table depending on the source data
e.g. local Value = Table["Key1"]["Key2"]
if there are no keys in the json/table use index numbers depending on the source data
e.g. local Value = Table[4][2]
you can also mix the two depending on the source data
e.g. local Value = Table["Key1"][2]
