jaclarkaus 0
Created a command to turn on a light at a certain time, then turn off sometimes later (in this example 3 minutes for testing)
The scene won't start at the time, but if I click 'run' the light turns on, then off at the right interval.
Not sure what's wrong.
Do you need to 'run' for it to start, or should it start at the selected time? If so, not sure why it turns on the light when I press 'run'
7 answers to this question
