Does anyone know if there is a function to switch off the lights function within the Alarm Panel? Reason I ask, I have an Everspring SE812 alarm and the only way (I don't have LUA experience as yet) that I can get the alarm to sound is by switching the "Controlled Device" to lighting and then activating this through "Scena PANIC" in the panel. When there is a breach this then switches the alarm on BUT...
The problem is that if you disable/stop the alarm, through an Android device's alarm panel all it does is disable the motion detector that was breached, and the alarm will continue to sound! I can use a scene to disable everything but doing this with the wife is in panic mode is just not going to work!
Any ideas?
rattyman, sorry action on disarm is still not implemented
