GlennNZ 0
Hi
Have been struggling to find the best way to break out of a loop with another button press in timely fashion.
eg.
Trigger - device - door sensor toggle
Sets global variable timer
Turns Devices On
While do loop until timer equals current time (sleep 5 or 10 secs)
When time up
Turns Devices Off
End of Scene
Example from Richo - whichs works great on a few other scenes.
Works well, count downs and turns off.
However I wish to turn these devices off if there is another button press on the same deviceId.
Options
- Within the loop Can check the deviceID status every 5 seconds and then turn off if triggered again - Quite a delay to turning off.
- Can check if scene running (fibaro:Countscenes) and if triggered again killscenes ? (would seem a bit 'aggressive') and countscene based triggers seem to run without clear trigger to me occasionally
- Is there an easier better way?
Glenn
[/code]
