FGS211 Switch 3kW triggering Scene on S2 - How?
Hi all, i want trigger a scene on the second switch of an FGS211 Switch 3kW. How can i do that? I think i have to LUA it because i have no access to the S2 with the block diagram. May be someone give me a hint.
6 answers to this question
Second switch should be available as device able to trigger scene in block diagram, please look for it once more.
    Show child device was off. That was my problem. Thanks for leading me in right direction.
    [ Added: 2014-06-12, 15:16 ]
    Can i make the switch triggering a scene on and off in block diagram? For example switching a bunch of lights on and off? I know how to switch them on but how can i switch them off without being in an loop?
    You can add another block after "Then" instruction, which will turn lights off, but add a delay in red field.
    if s2 is turn on
    then
    do some scene
    if s2 is turn off
    then
    do some scene
    Block or luup works.
    I DO NOT want a loop.
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />) I want a script which turns on a bunch of lights and turn them off when i toogle the S2 switch. Possible? I now use association but i'm not happy with it because it is restricted. I want switch more than five devices.
    [ Added: 2014-06-13, 18:13 ]
    Ok, thanks. It is working. I thought a script is always listen to the device and switching the lights on and off in an loop. But with triggering it is different. Now i know. So i made two scenes. Perfect!
    I would activate a scene with s2 of my fgs211, Should I associate it with HC2 first?
    How can I catch the button trigger with scene blocs or lua?
    I can't find the s2 as a device as
      described
