I can not associate my FGMS001 Motion Sensor EU to a FGS221 Switch 2x1,5kW EU. How come?
How can i handle that in other way?
Want to use parameter 12 in my motion sensor and turn off switch after xx times.
What do you mean by xx times? You can use parameter 12 to make sure switch reacts only on motion sensor switching on or only when it is switching off. And that feature should work fine.
    Well i could only associate master, not the slave.
    This feature is not supported by our devices so far, it will be added in next versions.
    Yes, i notice that. Have sorted it out with another function instead
