domoticapassie 0
I have a problem with hc2
suddenly the led recovery came on
after that i was not able to entre the hc2
i trie to reboot no results
than i tryed recovery and i was able to log in to the hc2, i cam in a recovery field where i only
coult only select recovering when i do it ask "Do you want to erase all devices from z-wave memory?" i select yes then i comes up with "The system drive could not be found."
Can somebody help me with this
