Hello. Can some one explain me how is it posible to record video from ip camera only by HC2 + WiFi camera (Foscam).
"I saw movement
Camera: record the image.
Turn on lamps,
because it is too dark for the camera."
as i understand if using only interface of HC2 it will be possible to make only photos.
How to create security system....If motion detected start recording video(for example save to home NAS), send push notification to Ipad, turn on siren.
You should create virtual device, which will send message to your camera (if it supports such actions) to start recording. Also you can use some kind of recording device and control it with virtual device. But you need proper camera/recording device to accomplish that.
  • 1 year later...
Is it possible to connect hc2 to a DVR recording device ?
  • 1 year later...
Search the forum for topics regarding "CCTV DVR" for connecting HC2 up. I've not found an ideal solution just yet as the DVR needs to support the crappy MJPEG standard for HC2 to be able to access its camera feeds.
Guest spazpeker
If you have a synology NAS you can use the inbuilt Surveillance station
