LUA to set scene active or not
kappnet
Hello all!
I need to get the LUA-code for setting a scene as active or not. The code is to be put into a virtual device that will set my home/away status.
Thanks a lot
Use this code, remember to change ip of your device, login, password and ID of scene you want to enable (in 3rd and 8th line). If you want to disable scene, just repalce 'true' with 'false'
