Virtual Device with WF2IR stopped working
Dear All,
I'm using the Globalcache WF2IR in order to control my AC unit. For this, I've created a virtual device which was doing the job perfectly!
After one week (today) it stopped working which means I cannot see the led from output1 blinking as it should when sending command.
The WF2IR is perfectly connected to the network (can access it buy http) and I can send command through "Ilearn" (globalcache learning soft) to it making the led blink.
I'm using 3.902 and the HC2 is on the same subnet as my WF2IR unit.
Any idea what could cause this?
Thank you very much in advance,
Disregard, a simple reboot of HC2 had solve the issue. I hope it will not happen to often...
