Double push notifications
Guest AxelS
Hi folks,
has someone the same problem that since a few days any push notification comes twice?
br
Axel
6 answers to this question
i have the same problem, but from the beginning.
Check if your scene doesn't trigger twice. You can avoid this by adding this line at the beginning of your scene:
You have notifications.... you are lucky... I have no notifications at all
kiwi, are your devices added to contol panel acces and is option "send notifications" checked? What kind of mobile devices are you using?
is it also possible to change the notification subject
it always says " Message from Fibaro"
Kage, there is not such function. But I will pass your suggestion further, for sake of customization of the interface.
