door check
Guest nohed
Guest nohed
can you make a lua that checks the doors using the door sensor and one that is open for more than x minutes to send a puch which door is open
Do a scene where door is opened is the trigger. start a countdown of x minutes. check if door is still open. if door is closed, stop the countdown.
Here you are... almost... doesn't send a push but a mail
