Motion Activated LEDs
I'm trying to create a scene to trigger some LED lights when the motion sensor is breached, I've found some good content of the the Vesternet site (LUA not an option as have the HC2 lite) but when replicating I'm not getting any joy.
Using: -
Fibaro Multi Sensor
Fibaro RGBW Controller
Scene logic (if images uploads otherwsie
I've set the scene to run at startup, set it to active, run it and also confirmed that the motion breached event is logged in the Event panel.
What am I missing???
4 answers to this question
Is motion sensor marked as triggering device? Above blocks you have checkboxes.
    It wasn't, have changed, re-saved with it checked and no difference
    Sorry i did not notice that you entered value 100 after "turn on" instruction. You should leave this field blank. That way the rgbw will enable with full brightness and previous color.
    Sorted! Thank You.
    Have also managed to extend to turn off after a safe period and activate during a certain time period.
