I tried to use a simple door check with a specific push-mail if door/window is open, but it doesn´t work for me. Could anyone help me to find the mistake?
%% properties
50 value
53 value
%% globals
if (fibaro:countScenes() > 1) then fibaro:abort() end;
local id = 50
if
( tonumber(fibaro:getValue(id, "value")) > 0 )
then
fibaro:call(5, "sendPush", "Haustuere offen")
else
local id = 53
if
then
fibaro:call(5, "sendPush", "Fenster WC offen")
else
4 answers to this question
Why do you have so many start source?
Try my code, definitely work.
    Yes, it worked! Great - honestly I only tried to combine some parts of LUA scripts to make them work (but I failed).
    haha if you are not very sure about lua coding, you can try the block scenes as well. They are good to go for your case.
    Yes, for sure. But I think there is no possibility to send a message with the name of the open door and this solution has no woman acceptance factor
