Dear All,
Is it possible to make a http request with Digest Auth in a virtual device?
Thank you in advance
[ Added: 2014-07-01, 16:28 ]
After many tests, I've found a solution:
What you need:
- a Webserver running php 5.0 or above
- Download
php class
- a simple php script with the http address and your authentication
- a virtual device that recall the php script
You can find the documentation about the authentication script
Personally I've used this code:
If you don't want to see the debug of the http request, cancel this code:
IMPORTANT: copy the nuSoap "lib" folder in the same directory of your script on your webserver, otherwise you must change the path:
In the virtual device add a button with this code:
Finally, I can connect my Toshiba TV!
