Loggin to MS SQL or MySQL
I have grown impatient with the lack of history for powerusage on my HC2. Everytime I upgrade the BOX Fibaro needs to clear my energy history which I do not like. So I grown impatient and want to log to SQL for backup. So Can I do something to log to SQL via for example a virtual device and a webpage or something. Any ideas?
7 answers to this question
With Beyond Measure you can log hc data to mysql. With Isakssons komponent
I do it and it works great.
Check here.
If you know a bit of scripting it is quite easy to do. I have a setup which works in this way:
- A button on a virtual device is activated by a scene (scenes can't handle http requests for some strange reason)
- the virtual device opens a http-socket to my webserver and activates a php-script by means of a get message.
- the phpscript imports the entire device json from the hc2, located at:
- the script then identifies the devices you want to log (i log everything of a specific device type, i.e. Plugs, or by means of a specific function i.e. "isBatteryOperated") and then exports the value and device ID to the database. A separate database stores the name as a function of id to avoid having to save the name in each value readout.
- the database can then be read out using a number of different graphing tools.
    Good variant. With this I can go from fibaro to domoticz and IF fibaro gets better I can even go back again without loosing energy history.
    Dall1985 can you share your php script / virtual device for this solution?
    thanks,
    Remco
    It would be very nice with a step by step how to log to MySQL. That is the only thing that i miss in HC:2.
    Yes, that would be great. Than I can finally create some statistics about my house. The HC2 doesn't store enought data to do this...
    If the only thing you are after is loggin numbers, you might be interested in ThingSpeak.com, which is a service with logging capabilities - then you simply do not need a MySQL server - just simple LUA code like:
