i've a big problem with fibaro roller shutter 2 ver 2.2;
I have installed the module, inserted into the ZWave network, but when I start with the calibration, the shutter does not go up or down.
I tried to reset it several times with the B button, but still the same problem. The shutter does not work even with the keys. The links are ok. The strange thing is that when I turn on the power, the shutter go up, then stops and does not go any more. What should I do? I installed another module and it works, I wanted to know if it is broken or just a particular hard reset. thanks
Have you tried removing and including the module again?
