Hello guys
I have a Json response to an http command that will give me alot of info.
The command is:
What i get is:
"SourceID": 0,
"QueueCount": 54,
"QueueSongIndex": 14,
"ChangeQueueID": 2,
"ChangeSlideShowID": 1,
"ChangeMetaDataID": 61,
"Status": 2,
"Controls": 51642623,
"RepeatMode": 0,
"ShuffleMode": false,
"CurrSong": {
"Flags": 12289,
"ID": "72a0263645a710284dfce03c3474d15f",
"Title": "Khalik Fakirney",
"Type": 32768,
"ArtworkURI": "http://192.168.1.215:10243/WMPNSSv4/2524841952/0_ezNDNDg4M0VELTBCMDktNDM5OS1BMDZGLUU0NTIzNzIxNUVGN30uMTQuM0I2QkUxQ0U.jpg?albumArt=true",
"Album": "Best of",
"Artists": "Amr Diab",
"Duration": 209,
"Genres": "Other",
"Released": "2009",
"Track": "15",
"BitRate": 176400,
"ListenerCount": 0,
"Rating": 75,
"TotalItems": 0,
"DisplayInfo": [
"Khalik Fakirney",
"Amr Diab",
"Best of",
"Other - 2009"
"NextSong": {
"Flags": 12289,
"ID": "07b03113edf1322f47bbff2af0a698d8",
"Title": "A3'eb A3'eb",
"Type": 32768,
"ArtworkURI": "http://192.168.1.215:10243/WMPNSSv4/2524841952/0_ezkzNUEzN0FGLUNFQ0YtNDQ4RS1CRTBBLUU0N0Q3NTEyNDJDNX0uMTUuM0I2QkUxQ0U.jpg?albumArt=true",
"Album": "Best of",
"Duration": 211,
"Genres": "Other",
"Released": "2009",
"Track": "16",
"BitRate": 176400,
"ListenerCount": 0,
"Rating": 75,
"TotalItems": 0,
"DisplayInfo": [
"A3'eb A3'eb",
"Amr Diab - Best of"
"CurrProgress": 176,
"SlideShowAvailable": false,
"SearchPromptText": "Search for music by artist, album, or title",
"SourceLockedByZoneID": -1
I just want to take the Title and the Album name for example and add them to a label in a Virtual device in HC2
Is there anyway to do so?
7 answers to this question
yes, read how to do that in virtual device
how to get json
and how to use json
    Thank you
    Yes Actually i have tried that
    json.decode(response)
    But how to proceed after that?
    HC22 = Net.FHttp("192.168.1.215",8735)
    response = HC22:GET("/api/v1/zones/0/nowplaying")
    jsonTable = json.decode(response)
    local Artist = jsonTable.Title
    fibaro:call(889,"setProperty","ui.Label1.value",Artist)
    fibaro:sleep(5000);
    Use that
    from there you will easer saw structure of json Title is under CurrSong
    Thanx it worked
    Guest berga_s
    Hi A.Socha,
    I'm tring to get the value stringForecast = jsonTable.forecast.txt_forecast.forecastday(0).fcttext_metric
    from the json string below using the json online editor to understand the structure.
    May be the sintax of forecastday(0) is not correct. What I'm wrong?
    Is there the possibility to print out the structure and values of jsonTable I've created with json.decode() function?
    thanks
    [ Added: 2014-09-19, 12:41 ]
    OK, solved!
    the right string is:
    stringForecast = jsonTable.forecast.txt_forecast.forecastday[1].fcttext_metric
    Use [] instead of () and the first value is 1 and not 0 as shoved by online editor...
    Hi berga_s,
    Yes, as you have discovered, in Lua, the default indexing of tables starts at 1, not 0.
    The code I just posted
    shows the correct key number if it will help you in the future.
    Adam Bewsher
    Guest berga_s
    Thanks a lot Adam!!!
    Very useful examples.
