Hello, is there anyone with lamellas rotation working with Fibaro Roller Shutter 2 actuator?
I think I've set everything according to instructions - the operating mode is set to Venetian blind mode, Parameter 3 (Reports Type) = 1, calibrated the positioning, tried various values for Parameter 12 & 13.
But pressing the rotation up / down buttons in the web interface (HC2 3.590) has no effect at all.
Did I forget anything?
Can you post print screens of advanced configuration options?
I think a have a similar problem. Using 4 roller shutters without any problems I bought 3 new ones. Most functions are working, but I cannot close the blind by e.g. 20%. The system does not react if I want to run down the shade a little bit. It works only if I run the shade completely up or down. Now I saw that my old 4 roller shutters where FGRM-221 and the three new ones are FGRM-222.
If Fibaro could give a little input it would be great.
Thanks!
Greetings, Dirk
[ Added: 2014-07-04, 13:10 ]
And here is the solution: First calibrate the shutter!
You find this in 'Advanced' and then 'Calibration'.
  • 1 year later...
hello
is it possible using a LUA code , change the position of the "Order Protection" parameter FGRM222 Module ?
  • 7 months later...
Same problem cant give you a screenshot i only have a pdf... somehow no idea what was customer doing to end up with PDF instead of screenshot but there you go.
in this case its HCL 4.100
  • 5 months later...
Same problem here using FRG-222 EU 2.5. I have already made the calibration process two times but there is no chance to set the lamella position. Any ideas?
you have to change paramet 10 on the master device. for some reason its set to value 1.
It needs to be set to 2.
will post the link to the original post when i find it again.
is the original thread that manages this tiny change which makes a big difference.
Edited by kroeatschge
I learned a hard way how to control slats (lamellas). For some reason, when you directly set after inclusion to Venetian blind mode, then you are not able to control slats.
After including or if you included FGRM-222 already:
  1. set FGRM-222 to control Roller blinds with/without positioning,
  2. Then go to device settings (Advanced tab),
  3. Set controlled device to Venetian blind,
  4. Calibrate it if you have not done that already.
Or you can try it @kroeatschge way.
Thank you
 !!! That is the solution!
Same problem to me.
And now solved, thanks!
Edited by Conso
Wow, thanks. I was getting nervous. Something Fibaro should fix ASAP.
Issue presented since 4.100.
