Hi there
is there a manual how to create scenes the best way with explemation of the parameters?
Maybe how to turn off the light automaticcly after x minutes or make a randomizer for the light ?
thank you
Angelo
Unfortunately there are only a few official descriptions available.
I took this one from Fibaro for the Web GUI
and several other from this forum, like "presence simulation" (search function) for random lights. But you need to use LUA for this (HC2).
    Thank you. But how do I configure that a light turns random on and off?
    Or a light switched on from a motion sensor turns off after 2min?
    Thank you
    Angelo
    donangelo, to turn light off just add another "turn off" block at the end (after "turning on" instruction), and enter 120s(2minutes) in the red field for delay. What do you mean by "random on and off"
    As J.Nowacki described you can create a motion acitvated light scene for 2 min easily with the Web GUI:
    Module Motion Detector = breached then Module Light = On for 2 min (red area).
    A random based light can not created with the Web GUI, only with LUA. Search the forum for "presence simulation" as I wrote before...
    I do agree with donangelo, there is no real documentation of how to do some super user stuff without going into LUA. I can not program myself but do like some extensive and complex scene building.
    I feel there is a need for more and deeper explanation of the system and the possibilities of building scene's.
